Doran_Lum's avatar
Doran_Lum
Feb 24, 2014
First Time setting up F5
Hi all, this is my first time setting up F5 VE from scratch which was different from managing one which is already setup.
I have both application server up & running and both server's firewall is disable. The F5 external IP and the server's IP are on the same subnet and no firewall in between.
1) It seems F5 is able to reach port 5005 and 80 but not 15005. I check back on both servers and port 15005 is in "Listening" state
Ltm::Node: 10.1.1.1 (10.1.1.1)
Status Availability : available
State : enabled
Reason : Node address is available
Monitor : /Common/icmp (default node monitor)
Monitor Status : up
Session Status : enabled
Ltm::Node: 10.1.1.2 (10.1.1.2)
State : enabled
Monitor Status : up
Ltm::Pool: QA_Pool_15005
Status Availability : offline
State : enabled
Reason : The children pool member(s) are down
Monitor : QA_15005
Minimum Active Members : 0
Current Active Members : 0
Ltm::Pool: QA_Pool_80
State : enabled
Reason : The pool is available
Monitor : QA_80
Current Active Members : 2
Ltm::Pool: QA_Pool_5005
State : enabled
Monitor : QA_5005
Current Active Members : 1
