zafer's avatar
zafer
May 06, 2009
fingerprint and timestamp security issue
Hello
i tested some bigip system vip address and i got timestamp and fingerprint information about system.
i found two solution on ask.f5.com
https://support.f5.com/kb/en-us/solutions/public/9000/400/sol9491.html
https://support.f5.com/kb/en-us/solutions/public/8000/000/sol8072.html
f5 tell us we can not hide OS information and timestamp
what do you think about these issues?
regards
zafer
  • hoolio's avatar
    hoolio
    Hi Zafer,
    I don't think anything has changed since the last post on this topic (Click here). Scanners will be able to determine the OS of the serverside--whether it's LTM or the servers behind it when LTM isn't in a full proxy configuration.
    I think you gain security by locking down your network and validating anything coming from the client--not obfuscating what architecture you're using.
    Aaron
  • zafer's avatar
    zafer
    Hi Aaron
    i thought irule can be fix this problem but i think this is tcpip problem on os level
    you know we can hide web server os information but i want hide our LTM os information
    you can use netcraft, nmap, nessus and find which device we have
    i have case about security check to virtual address but support guys does not validate to fix this problem.
    F5 box in production and everybody know which device running on customer site.
    if i am bad guy and i know xxx customer have bigip and i can attack the xxx customer
    thats the problem
    thanks
    zafer
