Suni's avatar
Suni
Mar 19, 2015
Finding "Active Device" of a traffic group
Hi, Is there any way to get the "Active Device" of a given traffic group using powershell? On the GUI, if you go to Device Management-> Traffic Groups, this information is displayed in the column "Active Device". I've tried various ways to access this info, and have so far been unsuccessful via Powershell.
Thanks so much!!
  • Hi Suni,
    I think you're looking for "show /cm traffic-group" command.
    Regards Mariusz
  • Suni's avatar
    Suni
    Hi Mariuz, I actually didn't know about that command. I just tried it in the tmsh shell and it worked great.
    However, I am trying to achieve this via iControl and specifically PowerShell if at all possible. Do you know if there is a way to get this information via PowerShell?
    Thanks so much!
  • Suni's avatar
    Suni
    Hi boneyard, I actually did and I am leveraging a lot I learned from that and other PS/iControl articles to do what I need in our environment (creating pools,healthchecks etc), but, I have so far not been successful in being able to connect to a F5 unit that is part of an HA pair, running Active/Active, where some traffic groups are on one unit and others are on the other unit, and get which unit is currently active for a given Traffic Group. -Suni
