Filtering client IP using HSL in irules
set hsl [HSL::open -proto UDP -pool SYSLOG_POOL] set http_request_time [clock clicks -milliseconds] HTTP::collect 4096 set LogString "<190> [IP::client_addr]:[TCP::client_port]->[IP::local_addr]:[TCP::local_port]; [HTTP::host]"
host header translation function
HSL::send $hsl "$LogString REQUEST HOST HEADER TRANSLATED -----> [HTTP::host]"
when HTTP_RESPONSE {
set hsl [HSL::open -proto UDP -pool SYSLOG_POOL] HSL::send $hsl "[IP::client_addr]:[TCP::client_port]->[IP::local_addr]:[TCP::local_port] RESPONSE FROM SERVER ---> [LB::server])"
Enclose the logic in an if statement:
if { [IP::addr [IP::client_addr] equals 1.2.3.4] } { execute existing code }Make sure to do it in both events and you should be fine.
/Patrik
