Dawn_Parzych_20's avatar
Jan 05, 2006
Failover to standby device if health check fails
I want to set up a standby pool to be used only if the primary pool fails. Would an iRule be used to determine if the healthcheck fails on pool 1 then use pool2.
  • I have found a solution for this issue. Set up 2 pools one with the active devices one with the standby devices. If the healthchecks all fail then the following irule kicks in
    when LB_FAILED {
    LB::reselect pool Pool2
