woody_46's avatar
woody_46
Apr 20, 2026
F5 Visual Studio Code extension not listing Big IP device partitions for 17.5.1.5 QKViews
As a general practice, after I upload qkviews to iHealth I then copy them to my visual studio code workspace. In the past, pulling them up using the Big IP extension, it would show all the source conf files and partions. For all 17.5.1.5 qkviews I've generated this past weekend, none of them have the source/partition data.
Is this a bug, did F5 change something in the way this new build processes qkviews? The extension is pretty much worthless without it. To be sure it's limited to 17.5, I pulled up several 17.1.3.1 QKViews and the partitions/sources loaded fine.
  • Hello woody_46​
    Thanks for posting the issue your having with iHealth. I have done some digging and reaching out, it doesn't appear there are any changes that would impact this. I would suggest in this instance to create a support case to have it reviewed by an engineer for a protentional bug.
    -Melissa
