ciscoarc's avatar
ciscoarc
Apr 02, 2014
F5 VE with VMWare problem
Hi guys,
I just built the F5 VE with vmware, and I've been stucked for days.
So we use 2 physical NIC and trunked 4 VLANS onto the F5 (let's say Internal, External, DMZ and Mgmt).
  • Internal: 192.168.1.x /24. Self IP 192.168.1.100
  • External: 192.168.2.x /24. Self IP 192.168.2.100 and 192.168.2.250 (this is for the Virtual Server)
  • DMZ: 192.168.99.x /24
  • Mgmt: 192.168.100.x /24
Next step would be creating the Monitor, Node, Pool and Virtual Server. All are good here.
  • Virtual Server 192.168.2.250:443 -> Pool Member Test_Svr -> Node 192.168.30.250:5000
Routing table in F5:
  • Default (0.0.0.0) via 192.168.99.254 (DMZ interface in firewall)
  • 192.168.30.250 /32 via 192.168.1.254 (Internal interface in firewall)
VLAN in F5:
  • Internal, untagged 1.1
  • External, untagged 1.2
  • DMZ, untagged 1.3
I then had a client fires up the application destined to 192.168.2.250, but couldn't access the Node.
Troubleshooting from the firewall shows that the F5 doesn't use the internal interface 192.168.1.100 to reach 192.168.30.250, although in the routing table it's specifically instructed to use 192.168.1.x.
My question is definitely, why didn't F5 use it's internal interface? I assume it's something wrong with the VMWare configuration for the network setup, but I am not sure. Reason is, we have a production physical F5 which have similar configuration and it works fine.
Any help is appreciated.
Thank you.
