Suresh_Jo_32729
Jul 16, 2018F5 syslog reporting issue
With High Availability F5 pairs, should we expect to see syslog logs generated from all nodes in a cluster, or will logs only be sent by the active member of the cluster?
Do we need to restart log forwarding services after updating a logging destination for the change to take effect?
- Suresh_Jo_32729
Hello,
Can someone pls look into this and reply?
- youssef1
Cumulonimbus
the logs are sent by the 2 members of the cluster but be careful you have to diferentiate them.
Active memeber will sent:
- Business logs (which is normal because it is this active memeber that manages the traffic): APM, ltm (Irule), ASM, ...
- System logs: error, audit...
- HSL that you set
- request logging
Standby member will sent:
- only system logs: audit, error, ....
Hope it's clear, keep me in touch if you need more details.
regards
