F5 SSL offloading and Port redirection
Dear Support,
I need your help on to create a https VIP on F5 that terminates SSL from the client and send http traffic to the server on
- Michael_Jenkins
You can set up the VIP with a client side ssl profile and an http profile to offload the HTTPS traffic, and then assign it a pool whose member(s) are set up for port 19000. On the VIP configuration if you change the
toConfiguration
from Basic, I think theAdvanced
andAddress Translation
options are automatically checked, which should accomplish what you're asking for.Port Translation - Max_Q_factor
Cirrocumulus
You also might want to add an irule to redirect people from the root page of say to with an irule like:
when HTTP_REQUEST { HTTP::redirect https://[getfield [HTTP::host] ":" 1]/workspace/index.jsp } - Peter_Salama_20
I have tried below iRule and the redirection is happening for the URI but the protocol is http instead of https
when HTTP_REQUEST { if { [HTTP::host] equals "website"}{ if { [HTTP::uri] equals "/" } {
HTTP::redirect "http://[HTTP::host]/workspace/index.jsp" }} }
- Max_Q_factor
Cirrocumulus
It appears that the back end is HTTP but HTTPS from the client's prospective. Have you tried changing your redirect to "https://[HTTP::host]/workspace/index.jsp" ?
- Michael_Jenkins
How about this? If the URI is empty, it'll redirect to workspace/index.jsp (using the same hostname)
when HTTP_REQUEST { if { "[string tolower [HTTP::host]][HTTP::uri]" equals "www.example.com/" } { HTTP::redirect "/workspace/index.jsp" } }
