F5 Self IPs are making ping scan with a huge concern Index as per Lancop report - Ping_Scan
Hi, I have multiple VLANs in LTM, as per the security team that F5 Self IPs are making ping scan with a huge concern Index as per Lancop report, example below : 5/19/2014 23:59Catch All10.2.1.810.15.4.0/2411819592Ping_Scan(23592) 5/19/2014 23:59Catch All10.2.1.910.15.4.0/2411104164Ping_Scan(22164)
Can u please advice what is this behavior? and Is it normal ?
Regards, Kasem
- Cory_50405
Noctilucent
They could be misinterpreting ICMP type health monitors as ping scans. These health monitors would source from your non-floating self IP addresses. Do you have any pools using ICMP type monitoring?
- Kasem_Badwi_144
yes I am monitoring using the ICMP type, all-most all pools using ICMP monitoring pool. - Cory_50405
Noctilucent
Then it sounds like you have legitimate ICMP traffic, as long as it's sourcing from the non-floating self IP address on your LTM.
- What_Lies_Bene1
Nodes also use the ICMP health monitor by default.
