Gudalam
Feb 09, 2017F5 Monitoring best practices for stable environment
Can anyone please suggest me what kind of monitoring is best to maintain F5 environment stable.
- Vijay_E
Cirrus
Assuming that you are talking about health-monitors that F5 utilizes to check the servers, it depends on your application.
Ideally, keep it Layer-7 at the pool member level. Example: HTTP (GET Request). Don't use monitors at node level as this is really not required since you are monitoring the pool members at L7 and if node fails, L7 check on pool member will fail automatically.
In short, monitor the higher layer availability for pool members.
