Koalan's avatar
Koalan
Icon for Cirrus rankCirrus
Nov 04, 2019
F5 Monitor - Need help
So I have this friend who want a health check based on this:
F5 should check for:
curl -d @"xml_test.xml" -H "Content-Type: application/xml" -X POST http://usabc-31.abc.com/wfc/XmlService
the response should be:
<?xml version='1.0' encoding='UTF-8' ?>
<Kronos_WFC TimeStamp="10/24/2019 11:57PM GMT-06:00" version="1.0" WFCVersion="8.1.3.1531">
  <Response Status="Success" Action="ping" Object="System">
  </Response></Kronos_WFC>
which is the .xml file
Can you help me please to have a health monitor for this kind of scenario, btw usabc-31.abc.com is a server being load balanced on our F5.
  • this is the complete curl if this will help:
    curl -i http://10.38.7.34/wfc/XmlService
    HTTP/1.1 200 OK
    Cache-Control: no-cache, no-store, must-revalidate
    Pragma: no-cache
    Content-Type: text/xml;charset=UTF-8
    Content-Language: en-
    Server:
    Set-Cookie: JSESSIONID=MN6llVUFVYrsx7PNDWV-u1ORx8_l5pfIKuYafBgr.uszyc-kronosp31; path=/; HttpOnly
    Referrer-Policy: same-origin
    X-XSS-Protection: 1; mode=block
    X-Content-Type-Options: nosniff
    Date: Tue, 05 Nov 2019 06:24:56 GMT
    Content-Length: 245
    <Kronos_WFC>
      <Response Status="Failure" Message="WFP-01110 The MIME type of the request is invalid. Type Found: . Valid types: text/xml, application/xml." ErrorCode="1332">
