F5 loadbalnce configs and Apache plus Weblogic
we had requirements to load balnce two front Apache server and 2 weblogic servers. F5 configured as ssl offloading for Apache VIp and Weblogic port is confiured on 9000 port
according to app owner Users are re-directed back to the login screen after a successful login attempt. on HTTP profile on Apache VIP is enable rewrite to "matching" alos add WL-Proxy-SSL: true.per :https://devcentral.f5.com/Community...fault.aspx .
any help .
thx
- What_Lies_Bene1
Can you tell us what persistence method you are using please? Also, is there anything in the server logs? - KJ_50941
we used Cookie persistet on Apache and source address on weblogic.
it appears user loosing session. how both VIP can keep seeeion on F5? - What_Lies_Bene1
Can you confirm that the clients are getting and sending the persistence Cookie? (You can use LiveHTTPHeaders for FF, HTTPWatch or IEWatch for IE) - What_Lies_Bene1
Also, are the clients using a proxy? Plus, do you have OneConnect enabled? - KJ_50941
ok, now it is working and my session stay, however I am not getting load balnce, always stick to one server. it doesn't load balnce. will one conenct fix it.
'thx for help. - What_Lies_Bene1
Persistence overrides load balancing. What's not being balanced, Apache or Weblogic? I ask as you don't really need persistence for the Apache to Weblogic traffic I believe. OneConnect might help but that depends where the issue is.
- KJ_50941
weblogic servers are not load balanced. I see new conenctions hitting same box every time, we have Source address Pesist on weblogic and cookie on apache site. also since we have 2 VIPS( one Apache, anotehr weblogic? how F5 keep persist between two VIP on F5?
if I am not mistaken one conenct needs to be applie to Apache?
thx - What_Lies_Bene1
OneConnect would be a good thing for the Apache Virtual Server. I'd recommend you don't use persistence for the Weblogic Virtual Server; as you are discovering it can upset load balancing when there are only a few sources (your Apache servers). BTW, what LB method are you using for the Weblogic servers? - KJ_50941
for Weblogic and apache we are using least conn( nodes). what is the best seclection.
I'd say that's a good choice as long as the Apache to Weblogic connections are short lived which I'm sure they will be. So, are you able to remove the Weblogic Virtual Server persistence?
