Milady_KC_11599's avatar
Milady_KC_11599
Aug 13, 2017
Solved
F5 Lab Module 3
Hi! I'm following the F5 Lab. I finished Lab 1 and 2 within 2 hours and the next day I tried to open the 3rd lab. It brings me to the Setup Utility and I cannot see the System where I can import the Module3_Lab_begin.ucs. Am I going to repeat Lab 1 and 2 again? I don't think I can finish Lab 3 within 2 hours if Im going to repeat it again.
Pls help. Thanks!
  • I just tried to log back in yesterday and it is already good. Back to normal with no license issue.
    Thanks for the comments.
  • Update:
    I tried to do the setup again. And import the Module3 lab UCS but going to the network map I don't see the pools. And license is not activated....
  • ah, perhaps it has an issue or such. is there a contact there you can reach out to?
  • If you are using one of the labs that you accessed over F5 University that is in the SkyTap environment, and you are still experiencing an issue, you can send an email to wbtsupport@ for help.
  • HI Milady :
    i guess you ucs file is from different device . i suggest renew you F5 Essentials WBT Lab. it will be good way.
    if on next time, you want to restore f5 ucs on you don't device .
    use command line, it will be fine.
    tmsh load sys ucs 2017xxxx_F5_WBT_Module3_lab.UCS no-license
    have a good day!!!
