F5 BigIP and Citrix XenApp published apps problem
Hello Guys,
Please help me out here, pulling my hair out. I have the below set-up and any guidance on how to make it work behind a load balanced external IP would be much appreciated.
1.) 87.x.x.x Self IP External VLAN
2.) 87.x.x.x Virtual Server Destination IP
3.) 10.0.0.9 Self IP Internal VLAN
4.) 10.0.0.5 Xenapp server 1 [XML,Web]
5.) 10.0.0.6 Xenapp server 2 [XML,Web]
I know I should not have my XML Service and Web Frontend Servers on the same servers but they are for testing purposes, I cannot seem to launch my published applications at all.
This works on the same subnet. Please what am i missing
1.) A SNAT on the F5
2.) Secure access setting on the web servers
Please point me in the right direction.
Dipopo
Did you use the iApp and the deployment guide to configure this setup? If you just use the iApp, thing should work fine. What is the exact issue? If you can get to the Web Interface but cannot launch applications, then check to see if the SSL certificate you use is valid/properly chainged/trusted by the browser.
