F5 802.1x/ NAC Solution
Hey guys, Do you know if F5 have any type of 802.1x/NAC solution product? I have a customer that has some Windows XP machines and laptops running a specific engineering software, and those machines cannot be migrated to Windows 7. This is one of their challenges, but they also want to addresses non-compliant computers, so only 802.1x alone would not help to achieve this requirement. Any suggestions on the F5 side of things?
Thank you very much
F5 has no 802.1x solution in its portfolio. You can use APM to secure access to your apps or networks (VPNSSL).
You can achieve client side checks like (firewall, antivirus, etc.) with Endpoint Security Check feature.
You can find more info at http://support.f5.com/kb/en-us/solutions/public/15000/300/sol15332.html?sr=39703509
