Extract hostname from URL using the edge client
The user is connected to the edge client in the ipad or iphone. We have a Virtual server with a network access for setup for that. They then open the browser and browse to an internal URL which is pointing to a load balancer in the same F5 box. I would like to extract the hostname the user is entering in the browser through the VPN tunnel. Any ideas? I have tried using an iRule on the Load Balancer virtual server using http_request but that does not work. I also tried to use an APM in the load balancer so I could call ACCESS_POLICY_AGENT_EVENT but it doesn't look like I can have an access policy in the load balancer since it's using an internal IP and there is already a session created with the VPN access policy.
- What_Lies_Bene1
Hmmm. What would you like to do with that hostname, log it? Did you apply the iRule to the network access virtual server or the internal website virtual server?
- Dennis_Andrade_
The iRule is applied to the internal virtual server (Load balancer). The backend servers listen on different hostnames for different applications. So the user coming in might not have access to application A but do have access to application B. We need the hostname to allow or deny the user access to the application.
- What_Lies_Bene1
OK, so I don't see any reason it shouldn't work. Can you post the rule please?
- Dennis_Andrade_
This code works if we have only the ACCESS_ACL_ALLOWED. If I Add the HTTP_REQUEST the access to the application hangs. Don't see any errors in the LTM logs. For the ACCESS_POLICY_AGENT_EVENT, I added an access policy and added and iRule event in there allowing everybody access but I added a log in that section and the access policy doesn't seem to kick in.
when HTTP_REQUEST { set ::temphost [HTTP::host] } when ACCESS_POLICY_AGENT_EVENT { ACCESS::session data set session.custom.host $::temphost } when ACCESS_ACL_ALLOWED { set user "[ACCESS::session data get "session.logon.last.username"]" HTTP::header insert X-UPN $user } - Kevin_Stewart
Employee
I just tested this and it seems to work. I can see where you wouldn't want to use APM on the internal VIP, but you should certainly be able to see HTTP request events on the internal VIP inside the VPN. If you remove the access profile from the internal VIP, keep the HTTP profile, and then use the HTTP_REQUEST event only on the internal iRule, do you get to the application(s)?
