External Script Cron | using tmsh mark down by monitor
Hello;
My goal is to summarize several monitors in one external script. This script will run on a cron. Based on the result I would like to mark down by monitor using tmsh.... The only options I have is state [ user-up | user-down ] session [user-enabled | user-disabled] I tried state down but it didn't work...
Please advise...
- Stefan_Klotz
Cumulonimbus
Hi Navarro,
if you are in the LTM Pool prompt:
(tmos.ltm.pool)
you can use:
modify members modify { { state user-down } }to set the status of this member to "Force offline" or:
modify members modify { { session user-disabled } }to just "Disable" the member.
But I think both is not what you are looking for. How does your external script looks like and what about the option to use it as an external monitor? I think that should be your preferred option.
Ciao Stefan 🙂
