Julio_Navarro
Jun 24, 2014external monitor iapp check all FQDN using curl
hello;
i have a script working perfectly using curl,ntlm,etc.....
Now, how I can pull all the FQDN from the iApp script and test it inside the script?
Is this possible?
Thank you
- Kevin_Stewart
Employee
I'm almost afraid to ask, but in lieu of any response at all, are you trying to do a cURL request inside an iApp? - Julio_Navarro
Hi. I am using cUrl in a external monitor. Because you have several FQDN inside the iApp, i would like to have it update its (script) dynamically in case the iApp is updated (example: adding a new URL or removing one)
