Helena_101649's avatar
Helena_101649
Dec 02, 2010
External HTTP monitor for Citrix XML Broker
In Deployment Guide "Deploying the BIG-IP LTM v10 with Citrix Presentation Server 4.5"(version1.1) there is an example about how to monitor XML Broker. Basically, It's an HTTP monitor doing a POST of some xml data querying for a published application. But this monitor don't work (for version prior to 10.2.x) due to the issue described in SOL1033( Configuring an HTTP application health monitor to send a POST request): "the bigd process automatically appends one or two CR/LF sequences to the end of the monitor Send string".
An HTTP monitor created as described in the deployment guide leads to an HTTP 400 Bad Request.
The solution: an external monitor doing the same thing with curl. For this I used the script in
http://devcentral.f5.com/Wiki/default.aspx/AdvDesignConfig/HTTPMonitor_cURL_BasicGET.html
with the following customization for XML Broker:
curl -fNs -H "Connection: close" -H "Content-type: text/xml" http://${NODE}:${PORT}${URI} -d "@/usr/bin/monitors/test" | grep -i "$
The XML data is in the file /usr/bin/monitor/test:
no-load-bias
TEST_APPLICATION
"TEST_APPLICATION" is the application published by the Broker.
The variable $URI is specified in the external monitor definition: URI = /scripts/wpnbr.dll
The Recive string I check for is also specified in the external monitor definition: RECV = IMAHostId
This issue seems to be solved in version 10.2.x (SOL10655: Change in Behavior: CR/LF characters appended to the HTTP monitor Send string), but I haven't test it yet.
Hope that helps.
