Extend capacity of the blade on Velos
Hello everyone,
for a customer I need to buy another blade for Velos system that permit to extend the capacity of the disk,
at the moment i have cofigured a single blade that is it used at 85%, the target is to buy another one, for having a logical drive that is thwe sum of both hard drive. Is it possible to do it ?
I have read documentations about it but, i have not found the correct information, in addition you have to say that now, in the first balde there are 9 Tenants who are working in a production environment, so that, the goal is activities, for add the new blade, should not have impacts on the production.
Many thanks , in advanced, everyone.
Awaiting news,
- Melissa_C
Moderator
Hello unavailable
I saw you hadn't gotten a response yet, to help you with some direction If you haven't already I would suggest speaking with sales as they will will be able to answer best based on the current set up you are working with.
-Melissa
- unavailable
Hello Melissa,
I read on the F5 portal a solution K000149665 - apparently, it seems there are no repercussions on the tenant.
To be honest, I will open a ticket for F5 to make sure that, when I carry out the activities, the services will continue with no outage.
Many thanks for your time and consideration.
Rgds,
-Paolo
- unavailable
Hello Melissa,
many thanks for your fast reply.
I will follow your suggestion.
Many thanks again.
Rgds,
