Exempt http to https url redirection for specific IP addresses in Irule
Hello,
I have a VIP with with address 10.20.20.20 which configured to use SSL. http to https redirection also configured on the F5 so that users will be redirected to if they access http.
now I want to bypass the http redirection for some users with specefic IP addresses (Means users with ip address 10.55.22.22 should access http url and should not use SSL). I have an Irule for this but it is not working. Can anyone help me with this.
if { [IP::addr [IP::client_addr] eq 10.55.22.22] }
return
do nothing
else {
HTTP::redirect https://[HTTP::host][HTTP::uri] }
-Jinshu
- Brad_Parker
Cirrus
Are you using route domains? You may need to string the RD off of the client_addr.
when HTTP_REQUEST { if { [IP::addr [getfield [IP::client_addr] "%" 1] equals 10.55.22.22] } { return do nothing } else { HTTP::redirect https://[HTTP::host][HTTP::uri] } } - ssievers_87378
Hi, i think you have to configure 2 VS. One for SSL and one for http. Then you can configure your rule to the VS for http. Regards - Jinshu
Cirrus
I have separate VIP for 80 and 443. I have applied the irule on 80 vip only but it is not working. I am getting page cannot be displayed. - ssievers_87378
Is there a default pool configured on your VIP 80 ? Try this:
when HTTP_REQUEST { if { [IP::addr [IP::client_addr] eq 10.55.22.22] } { pool my_pool_for_http } else { HTTP::redirect https://[HTTP::host][HTTP::uri] } }
