Jasa_74968's avatar
Jasa_74968
Feb 04, 2014
Exchange 2010 and Commvault Simpana V10 issues
Hi all,
I've got a bit of an issue since we upgraded our Commvault Simpana from v9 to v10 with recalling archived emails from stubs.
What we have is: Client->F5(SSL Offload)->CAS Servers,Commvault Web server CAS servers are configured
Client is targeting "casarray.example.com" that points to a VS on F5 (config done through iApps) with SSL offload and it works fine. Commvault has a VS on a different IP pointing to single Commvault Web Server (IP_address_of_Commvault_VS) With Simpana v9, recall of messages went from CAS server to Simpana proxy and message was delivered to the client through CAS server.
In v10, Client gets a 302 response from CAS server pointing him to "http://simpanawebserver.example.com/webconsole/RestServlet/Recall?dynamicmessagestring".
I've tried with HTTP profile that has Rewrite_redirect set to all with no success so I've put in an iRule:
when HTTP_RESPONSE { if { ([HTTP::is_redirect]) and ([HTTP::header "Location"] starts_with "http://simpanawebserver.example.com/") } { HTTP::header replace "Location" [string map {simpanawebserver.example.com IP_address_of_Commvault_VS} [HTTP::header "Location"] ] } { log local0. "Rewriting to http://IP_address_of_Commvault_VS/"
I get plenty of hits in the Log saying rewrite has happened but don't see client then hitting the rewritten URL as if nothing happens.
What am i missing?
