EKON_26654's avatar
EKON_26654
Aug 24, 2010
evict_ramcache_entry_v2 method.
Hello,
Is there a way to use any of the evict methods under RamCacheInformation interface to delete only certain cache objects? Like say that I want to delete only the *.jsp uri, is there a way to do that? I can see (from the API documentation) that the method evict_ramcache_entry_v2 only allows me to delete an exact match, but what if want to delete all the uri objects for the same hostname that end with a .jsp?
Thanks.
