fmartos_30060
Mar 18, 2010Error: SSL hudfilter not reached or not in chain
hi,
we're using alankila iRule to authenticate users with an SC (http://devcentral.f5.com/Wiki/default.aspx/iRules/RequestClientCertificateAndPassToApplication.html), and I'm receiving this message in my log:
error: SSL_XXX_XX - Error: SSL hudfilter not reached or not in chain (line 1)
invoked from within "SSL::cert count" peer expression (line 8)
invoked from within "clientside {
Security: reject any user-submitted headers by our magic names.
HTTP::header remove "XX-XXXXX-Client-Cert"
HTT..."
Any suggestion?
- L4L7_53191
Double check that you've got your SSL profile enabled on the virtual server.
-Matt - fmartos_30060
Posted By L4L7 on 03/18/2010 5:31 AM
-Matt
The VS has a clientssl type profile applied:
profile clientssl XXXXXXXX {
defaults from clientssl
key "XXXXXXXXX.key"
cert "XXXXXXXXX.crt"
chain "XXXXXXXXXX.crt"
} - hoolio
Do you have non-SSL connections allowed on the client SSL profile attached tot he VIP? Your snippet doesn't show it, but that's one reason I can think of that the SSL filter wouldn't have been reached on a VIP with a client SSL profile enabled. Or are you disabling SSL in an iRule with SSL::disable?
Aaron
