David_G__33241
Jul 29, 2014Edge Client Localization
The French localization for the Change Server and Show Graph text does not fit the size of the buttons defined in the Edge Client:
Is there a way to either:
- Change the size of the buttons
- Change the actual translation
- Change the font size of the text in the buttons
Localization is pretty straight forward for anything that is browser based however I cannot find where it is defined for the Edge Client. From what I can see, it is not in apm_edge.css. Is there another file somewhere that can be modified or is this buried in the exe?
- David_G__33241
I opened a support case for this and reported it as a bug. It has since been fixed in a more recent version of the Edge Client. - amolari
I saw in 11.6 HF4 Release Notes
486344-2 French translation corrected to properly fit buttons in BIG-IP EDGE client on Windows.
