TalNe's avatar
TalNe
Sep 05, 2016
Edge client - client checks failed on Android platform
Hello, It seems that there is a problem with checking "Edge client - client checks" on android platform. I'm trying to check for specific process running on the system. I can check if the process is running , from the ADB shell - > ps | grep , however the Edge-Client failes. Another thing, I'm trying to check for a specific file location ,in the /sdcard/ or /data/app paths with no success.
The Android device is 4.2.2 Rooted Rom. Thanks in advance!
