easy way to learn Tmsh commands ?
Recently our f5 lb's have been upgraded from 10. version to 11. version. is there any easy way to learn Tmsh commands?
- nathe
Cirrocumulus
BJ,
This is probably a good starting point if you're familiar with bigpipe.
Also, check out the tmsh reference guide for your particular tmos version from the Documentation section of askf5.
Finally, tmsh commands can be populated using the tab key to auto-complete. Always useful.
Hope this helps,
N
- dragonflymr
And of course there is basic help when using ? after entered command. Considering tab auto-complete you have to enter tmsh before it starts to work, so type tmsh enter and then it works when entering further commands.
Piotr
