Julio_Navarro
Oct 16, 2015Dynamic Variable - Node IP - https monitor
Hello;
I am trying to find a way to have the "GET" option have the IP of the node being monitor:
GET /common/access.asp?REFR=https://{$IP}/dummy/site.asp\r\n
{$IP} will be replace by the IP of the node being monitored.
Please advise
Thank you
Julio
- Andy_McGrath
Cumulonimbus
Two options: 1. Either configure a monitor per pool member/node and assign directly under each pool member (instead of the pool) 2. Configure an external monitor, the following external monitor script should work for you.
!/bin/sh This removes the IPv6/IPv4 compatibility prefix. This has to be done because the LTM passes addresses in IPv6 format. IP=`echo ${1} | sed 's/::ffff://'` PORT=${2} PIDFILE="/var/run/`basename ${0}`.${IP}_${PORT}.pid" This will kill off the last instance of this monitor if it is hung and logs current PID if [ -f $PIDFILE ] then kill -9 `cat $PIDFILE` > /dev/null 2>&1 fi echo "$$" > $PIDFILE This is the meat of the code, it is responsible for sending the request & checking for the expected response. curl -fNs -k -v http://${IP}:${PORT}/common/access.asp?REFR=https://{$IP}/dummy/site.asp -H "Host: ${host}" | grep -i "${rstring}" 2>&1 > /dev/null This part of the code will mark the node UP if the expected response was received. if [ $? -eq 0 ] then echo "UP" fi rm -f $PIDFILE exit
