jay_41157's avatar
jay_41157
Dec 17, 2008
double wildcard match for uri patterns
Is it possible to use 2 wildcards when checking for a uri ?
For ex,
I want to look for
uri1abcURI2zzz
uri1xxxURI2wqq
so for the above can I do....
uri1*xxxURI2*
maybe with reg expressions ?
Thanks,
Jay
  • hoolio's avatar
    hoolio
    Hi Jay,
    You can use string match with multiple wildcards:
     string match -nocase "*pattern*" "some string"
    Or you could use the -glob flag for switch:
     switch -glob [string tolower [HTTP::uri]] {
        "uri1*xxxURI2*" {
    Either string-based option would be more efficient than a regex.
    Aaron
  • Aaron,
    Thanks for the response. However I am unclear on the syntax...
    how does the below look?
    if { [HTTP::uri] equals string match -nocase "portal/aaa/org/memberapp?*pageLabel=application*" } {
    HTTP::redirect http://redirecttotaget
    All I have a total of 3 patterns that i will need to check for... so should I just use or statements ? or try and integrate this with a matchclass I had run into problems using a wildcard with a match class in the past.
  • hoolio's avatar
    hoolio
    If you have multiple patterns you want to check, a switch statement would help keep them organized:
           Check requested URI
          switch -glob [HTTP::uri] {
             "*pattern1* -
             "*pattern2* -
             "*pattern3* {
                 Execute this code for the first three patterns
                HTTP::redirect "http://first_redirect.example.com"
             "*pattern4* -
             "*pattern5* {
                 Execute this code for the next two patterns
                HTTP::redirect "http://second_redirect.example.com"
             default {
                 Execute this code for the any cases that haven't been matched
                HTTP::redirect "http://default_redirect.example.com"
    Else, if you wanted to use a single if statement you could do something like this:
           Check requested URI
          if { ([string match -nocase "portal/aaa/org/memberapp?*pageLabel=application*" [HTTP::uri] ]) \
             or ([string match -nocase "*pattern2*" [HTTP::uri]]) \
             or ([string match -nocase "*pattern3*" [HTTP::uri]])}{
             log local0. "[IP::client_addr]:[TCP::client_port]: Matched check for [HTTP::uri]"
    Aaron
  • great, thanks. which option is more efficient in the irule ?
  • hoolio's avatar
    hoolio
    I've read in the forums and an old article (Click here) that an if statement is more efficient than a switch for a handful of comparisons. After that a switch is more efficient. At some point (around 100 elements) a datagroup would be more efficient than a switch. I haven't actually tested this before though.
    I'd guess the difference isn't huge for a handful of comparisons. I think it's more important that you use a form that's easy for you to read.
    If speed/resource usage is critical for you, you can test the versions using the timing command (Click here).
    Aaron
  • I dont think for this specific change we are at the point where speed / resource usage is an issues since this will be in place only for a couple of hours.
    I was curious if one was better over the other.
    Thanks for your help.
  • if i use:
    or ([string match -nocase [HTTP::uri] "/portal/acs/corg/memberapp?jay"]) that works, however if I use:
    or ([string match -nocase [HTTP::uri] "/portal/acs/corg/memberapp?*jay=*"])}{ -- seems like the * does not work as a wildcard...
    any thoughts ?
    thanks
  • the 1st or the second wild card neither of them are matched.
    I tried to use the below uri to test:
    /portal/acs/corg/memberapp?111jay=222; this does not match, I try to swap the *'s individually and same results. I will try to use \ for escaping ?
  • using:
    or ([string match -nocase [HTTP::uri] "/portal/acs/corg/memberapp/jay?*"])}{
    I get the * to work as a wild card.. what I need is to have a string append at the end of the wild card .
  • hoolio's avatar
    hoolio
    Sorry... I had the pattern and string reversed in my last post. It should be:
    string match -nocase $pattern $string_to_compare
    Aaron
