Malware_Mike_37's avatar
Malware_Mike_37
Nov 23, 2018
Does the f5-sdk work with Python3?
I believe I read somewhere that f5-sdk only works with Python2, can someone verify for this for me? Thanks!
  • The library is not Python3 compliant. It's Python 2.6 and 2.7 compliant.
    Although it's not altogether as cut and dried as that. Check out this issue on Github:
    https://github.com/F5Networks/f5-common-python/issues/287
    I've managed to get away with using Python3 in some cases but in other cases it borks.
    Best to stick to 2.6 or 2.7 for now although I suspect the pythonclock (https://pythonclock.org) may add urgency to any moves to port a compliant version as the countdown continues.
