Does the F5 Edge Client Support PPPoE?
Can anyone tell me if the F5 Edge Client supports PPPoE? Documentation states F5 BIG-IP supports PPPoE though I was not sure if this is specific to network tunnels or also includes client VPN.
- Leonardo_Souza
Cirrocumulus
The Edge Client has very little configuration, so the question is more if the APM supports VPNs with PPPoE.
This is first time a see a question about PPPoE and APM. As far as I know, the only protocol that is used for the VPN is SSL.
However, based on this ID:
https://support.f5.com/kb/en-us/products/big-ip_apm/releasenotes/product/relnote-apm-11-6-0.html
"445399Support was added for Network Access over PPPoE."
We can conclude that there was a limitation when using the SSL VPN on top of a PPPoE connection. Like if you have a ADSL modem, and connect to the Internet from your PC using PPPoE connection, and do the APM SSL VPN after.
