Brian_Martinez_
Nov 12, 2008Disabling pool member using iRule
Is there a way using an iRule that will disable a pool member at a specific time in order to do maintenance on that specific pool member?
Thanks.
- Festus_50639
I just went through setting up the same the same sort of rule last month. I also ran into a bit of trouble with not using the "-k" switch in setting the hour variable. You can find the variation I used here --> http://devcentral.f5.com/Default.aspx?tabid=53&forumid=5&tpage=1&view=topic&postid=2921029282.
It worked great for me once hoolio pointed out the error of my ways in which format option I was using.
Kevin
