Disabling alerts for power supply missing
We need to remove the second power supply and we want to disable the alert messages generated with the absent power supply. Did the command "modify sys db platform.powersupplymonitor value disable" disable all messages including possible errors in the active power supply?
Best regards.
- nitass
Employee
yes
anyway, there is a bug on 10000s and 10200v platform in 11.2.x.
ID389397 - Disabling the db variable platform.powersupplymonitor has no effect
- cjunior
Nacreous
BIGIP 3900 version 11.1.0 Thanks.
- nitass_89166
Noctilucent
yes
- cjunior
Nacreous
