MOHIT_125417
Altostratus
May 28, 2014Diiference between HTTPS & HTTPS_443 monitors
Dear Techies,
Please clear me the difference between HTTPS & HTTPS_443 monitor.
- nitass_89166
Noctilucent
https_443 can assign to wildcard (any) port pool member because port number is hardcoded in the monitor. 🙂
root@(B6900-R69-S5)(cfg-sync Standalone)(Active)(/Common)(tmos) list ltm monitor https https_443 ltm monitor https https_443 { cipherlist DEFAULT:+SHA:+3DES:+kEDH compatibility enabled defaults-from https destination *:https interval 5 ip-dscp 0 send "GET /\r\n" time-until-up 0 timeout 16 }- MOHIT_125417
Altostratus
Nitass it will be really helpful for me if you clear it by giving a example. thanks....
- nitass
Employee
Altostratus
- Vitaliy_Savrans
Nacreous
The difference between HTTPS and HTTPS_443 monitors is in Alias Service Port. Alias Service Port * All Ports - for HTTPS monitor. Alias Service Port HTTPS - for HTTPS_443 monitor.
- nitass
Employee
e.g.
root@(B6900-R69-S5)(cfg-sync Standalone)(Active)(/Common)(tmos) create ltm pool foo members add { 1.1.1.1:any } root@(B6900-R69-S5)(cfg-sync Standalone)(Active)(/Common)(tmos) modify ltm pool foo monitor https 01070622:3: The monitor /Common/https has a wildcard destination service and cannot be associated with a node that has a zero service. root@(B6900-R69-S5)(cfg-sync Standalone)(Active)(/Common)(tmos) modify ltm pool foo monitor https_443 root@(B6900-R69-S5)(cfg-sync Standalone)(Active)(/Common)(tmos) list ltm pool foo ltm pool foo { members { 1.1.1.1:any { address 1.1.1.1 session monitor-enabled state checking } } monitor https_443 }
