Willian_Guilher
Cirrus
May 06, 2015Difference between Virtual Server Forwarding (IP) and Forwarding (Layer 2)
Hi All,
I am trying to understand the exact difference and use cases for both Virtual Server Forwarding (IP) and Forwarding (Layer 2). can someone help to understand it?
- Samir_Jha_52506
Noctilucent
Please go thorough this link.
- kevinvpare_2028
The definition is easy enough to find and so is a use case for IP forwarding, but what is a use case for Layer 2 forwarding? I would like to see a typical client use case where Layer 2 forwarding addresses a requirement to use this technique.
- Russell
Hi Samir
I found these two answers on the forums, that might help understand the Layer 2&3 Forwarding?
