Tinnitus
Dec 03, 2013Difference between TCP monitor and SMTP monitor
Hi.
Will anyone be able to explain to me the difference between the normal TCP monitor (Alias port 25) and a SMTP type monitor?
For both type of monitor:
1. Will F5 close the connection graceful...
Emad
Dec 03, 2013SMTP default monitor in LTM only check that mail server is up and responding to commands. it marks mail server up if it responds to commands SMTP HELO and Quit.
you can for detail settings you can refer to
http://support.f5.com/content/kb/en-us/products/big-ip_ltm/manuals/product/ltm-monitors-reference-11-1-0/_jcr_content/pdfAttach/download/file.res/BIG-IP_Local_Traffic_Manager__Monitors_Reference.pdf
