Determine if users are connecting TLS or SSLv3
I'm running an LTM, version 11.4.1, that handles client-side SSL termination. I recently tried removing SSLv3 from a few of my sites, to force connections over TLS, but had several users complain, as they did not have TLS enabled in their browsers. I ended up turning SSLv3 back on, but now I need to know: Is there any logging or report that can show me how many / what percentage of connections are resolving to TLS versus SSLv3 for a particular virtual server?
- What_Lies_Bene1
You can't do this on a per VS basis but for global statistics use this menu path: Menu Path: Statistics > Module Statistics > Local Traffic > Statistics Type: Profiles Summary > Client SSL.
- Toby_Garcia_146
Altostratus
These statistics can also be seen from the CLI:
tmsh show /ltm profile [client-ssl|server-ssl]To reset the stats:
tmsh reset-stats /ltm profile [client-ssl|server-ssl]
