Chadri_103513
Mar 04, 2009Data-group entry limitation?
I was just wondering if there was a limit to the amount of entries you can enter in one data-group. Also, the commands to add or delete an entry from a class in the CLI don't seem to work as outlined in the man page. Is there any good way to add these commands in the CLI without having to recreate the entire class configuration?
- hoolio
What have you tried and what result do you see?
Aaron
