CVE-2014-3566 POODLE Vulnerablity fix. Which browsers will be impacted?
I need to implement the workaround for this vulnerability, however I'd like to be able to identify which browsers will no longer be able to access our sites.
Is there a reference document gives this infomation?
Thanks Stewart.
- Vitaliy_Savrans
Nacreous
POODLE affects older standards of encryption, specifically Secure Socket Layer (SSL) version 3. It does not affect Transport Socket Layer (TLS). Disabling the SSL 3.0 will avoid it.
- Stewart
Altostratus
Thanks Vitaily,
That's what I plan to do. My question was more around which browser users I'll chop off when I do it.
I think that IE6 users will have issues.
- Stewart
Altostratus
Thanks jgranieri the table is just what I need.
Nathan and Vitali, Thanks for your comments.
Hi Stewart, you might find this list from Mozilla helpful: https://wiki.mozilla.org/Security/Server_Side_TLSRecommended_configurations
