MikeyG's avatar
MikeyG
Feb 03, 2021
custom Monitor
I am trying to create a custom monitor for the URL https://telecom-phone.com wanting to check for https://telecom-phone.com/security/loggerd off, 200 OK
  • Create a simple https monitor & query for the monitoring page.
    create ltm monitor https TELECOM-HTTPS { interval 30 timeout 91 send "GET /security/loggerd HTTP/1.1\r\nUser-Agent: BigIP\r\nHost: telecom-phone.com\r\nConnection: close\r\n\r\n" recv "200 OK" recv-disable "Drain" }
    & bind this monitor to the LTM pool.
    • MikeyG's avatar
      MikeyG
      Thank you, i was damn close but your example helped me understand my mistake.
  • Send String - GET /security/loggerd HTTP/1.1\r\nHost: telecom-phone.com \r\nConnection: Close\r\n\r\n
    Receive String - 200
    Try to configure custom monitoring using above parameters and test.
