Create Domino LTPA token on F5 problem
I'm trying to use the code at
http://per.lausten.dk/blog/2009/06/how-to-create-a-ltpa-session-cookie-for-lotus-domino-using-f5.html
to create a Domino LTPA token but I am getting the following error showing on the Domino server:
Token does not lead with 0 [Single Sign-On token is invalid].
The token should begin with the version number 0123 e.g. from the code
set ltpa_version "\x00\x01\x02\x03"
However, after decoding the token and then looking at it in a hex editor the version number shows as:
C0 80 01 02 03 .......
Can somebody explain to me why the \x00 is being changed to C0 80 please?
I've experimented putting other numbers in thefirst position to see what happens e.g. \x01\x01\x02\x03 and the hex readout looks correct i.e. 01 01 02 03. It only fails when I use a \x00 in the first position.
Thanks for any suggestions.
Jeff
- Cri
Hi all,
have you got any news about this bug? I'd like to implement an iRule to generate LtpaToken in order to integrate new apps with legacy applications that are running on a mainframe, if there is a new version of this iRule could you please share it with the community?
We're running 16.1.4.2
Thank you all
Cristian
- John_45612
Hi Team. Anyone have this working still? We are running BIG-IP 11.3.0, Domino 8.5.2, and I am struggling to get the code to produce a valid encoded token. Can anyone share an example of the set ltpa_secret "b64encodedsecretkey" field, to give me a clue to what this should look like? Is this a direct copy out of the LTPA document in Domino LTPA_DominoSecret field, or do I need to change that value prior to insert into the iRule? Thanks in advance!
- Torti
Cirrus
i stay in front of the same challenge like jeff and try to implement LTPA token creation incl. Reverse Proxy with SSO. This is all new for me. We use 10.2.2 @ LTM incl. ASM.
So, if i try to create an irule with Jeff's code from above i get an syntax validation error in Irule editor:
Create binary formatted token.
set ltpa_token_raw_bin [binary a* $ltpa_token_raw]
--> [invalid option "a*" must be: format scan] [a*]
so for me, it looks like the line should be replaced by this:
set ltpa_token_raw_bin [binary fromat a* $ltpa_token_raw]
can someone confirm that behaviour?
Thx
- hoolio
Hi Jeff,
Thanks for posting the solution.
If you're on 10+ you can replace the global variables in RULE_INIT with static variables. This will function the same, but be CMP compatible. Using the global variables will prevent the iRule (and VS) from being processed on more than one TMM:
http://devcentral.f5.com/wiki/iRules.CMPCompatibility.ashx
There's a bug with the DC forums code when you use more than one code block in the quick reply box. You can click Edit on your corrupted post and then submit it as is to have it rendered correctly. Or you can click the reply button instead and use the full reply function instead of the quick reply option.
Aaron - Jeff_Green_4244
That alomst came out correct. The relevant line was:
Final Base64 encoded token
set ltpa_token_final [b64encode $ltpa_token_raw_bin] - Jeff_Green_4244
F5 have asupplied a workaround that seems to be doing everything correctly. We're going to test more thoroughly before declaring victory. The relevant line in the code is:Create binary formatted token. set ltpa_token_raw_bin [binary a* $ltpa_token_raw]
Here's the entire code that seems to be working:when RULE_INIT { set ::DEBUG 0 set cookie_name "LtpaToken" set ltpa_version "\x00\x01\x02\x03" set ltpa_secret "b64encodedsecretkey" set ltpa_timeout "1800" } when HTTP_REQUEST { Do your usual F5 HTTP authentication here Initial values set now [clock seconds] set creation_time_temp [expr { $now }] set creation_time [format %X $creation_time_temp] set expr_time_temp [expr { $creation_time_temp + $::ltpa_timeout}] set expr_time [format %X $expr_time_temp] set username [HTTP::header "username"] set ltpa_secret_decode [b64decode $::ltpa_secret] First part of token set cookie_data_raw {} append cookie_data_raw $::ltpa_version append cookie_data_raw $creation_time append cookie_data_raw $expr_time append cookie_data_raw $username append cookie_data_raw $ltpa_secret_decode SHA1 of first part of token set sha_cookie_raw [sha1 $cookie_data_raw] Final not yet encoded token set ltpa_token_raw {} append ltpa_token_raw $::ltpa_version append ltpa_token_raw $creation_time append ltpa_token_raw $expr_time append ltpa_token_raw $username append ltpa_token_raw $sha_cookie_raw Create binary formatted token. set ltpa_token_raw_bin [binary a* $ltpa_token_raw] Final Base64 encoded token set ltpa_token_final [b64encode $ltpa_token_raw_bin] Insert the cookie HTTP::cookie insert name $::cookie_name value $ltpa_token_final Loop through the list of Cookie headers to remove superfluous trailing semi-colons (known F5 issue) if they exist. Save the Cookie headers to a TCL list set cookie_headers [HTTP::header values "Cookie"] foreach cookie_header $cookie_headers { Check if the last character is a semi-colon if {[string range $cookie_header end end] eq ";"}{ HTTP::cookie remove LtpaToken Insert the header without the semi-colon HTTP::header insert Cookie [string range $cookie_header 0 end-1] } else { Insert the original header HTTP::header insert Cookie $cookie_header } } Remove Authorization HTTP header to avoid using basic authentication if { [HTTP::header exists "Authorization"] } { HTTP::header remove "Authorization" } if {$::DEBUG} { binary scan $ltpa_token_raw H* ltpa_token_raw_hex log local0.debug "LTP_TOKEN raw Hex: $ltpa_token_raw_hex" binary scan $ltpa_token_raw H* ltpa_token_raw_hex_bin log local0.debug "LTP_TOKEN raw_bin Hex: $ltpa_token_raw_hex_bin" set ltpa_final_decoded [b64decode $ltpa_token_final] binary scan $ltpa_final_decoded H* ltpa_final_decoded_hex log local0.debug "LTP_TOKEN decoded Hex: $ltpa_final_decoded_hex" } } - Jeff_Green_4244
Hi everyone,
Thanks for the input. I have opened a support case and will report back once they figure it out.
regards,
Jeff - I guess the function fails to convert it back.
sounds reasonable. Thanks for the link!
@Jeff: With all that information you should be able to open a support case.
Regards
Kurt Knochner - Minn_62043
From http://wiki.tcl.tk/1211
"In orthodox UTF-8, a NUL byte(\x00) is represented by a NUL byte. Plain enough. But in Tcl we sometimes want NUL bytes inside "binary" strings (e.g. image data), without them terminating it as a real NUL byte does. To represent a NUL byte without any physical NUL bytes, we treat it like a character above ASCII, which must be a minimum two bytes long:"
(110)00000 (10)000000 => C0 80
I guess the function fails to convert it back. - Hi,
it's a more general "problem" and related to the concatenation of strings, where the first string starts with \x00. 0x00 would be the terminator for a string in C. I'm not sure how TCL handles that. The strange thing is, that binary scan shows the correct value, while b64encode followed by a b64decode leads to the additional c080.rule irule03a { when RULE_INIT { set hello "Hello World" log local0. "WITH leading \\x00" set prefix "\x00\x01\x02\x03" log local0. "WITHOUT leading \\x00" set prefix "\x01\x02\x03" set text "${prefix}${hello}" log local0. "WITHOUT concatenation" set text "\x00\x01\x02\x03HelloWorld" set text_enc [b64encode $text] set text_dec [b64decode $text_enc] binary scan $text H* text_hex binary scan $text_enc H* text_enc_hex binary scan $text_dec H* text_dec_hex log local0. "Text: $text" log local0. "Text hex: $text_hex" log local0. "Text encoded: $text_enc_hex" log local0. "Text decoded: $text_dec_hex" } }
Nov 9 04:45:36 local/tmm info tmm[5158]: Rule irule03a : WITHOUT concatenation
Nov 9 04:45:36 local/tmm info tmm[5158]: Rule irule03a : Text: ÀHelloWorld
Nov 9 04:45:36 local/tmm info tmm[5158]: Rule irule03a : Text hex: 0001020348656c6c6f576f726c64
Nov 9 04:45:36 local/tmm info tmm[5158]: Rule irule03a : Text encoded: 414145434130686c62477876563239796247513d
Nov 9 04:45:36 local/tmm info tmm[5158]: Rule irule03a : Text decoded: 0001020348656c6c6f576f726c64
Nov 9 04:46:01 local/tmm info tmm[5158]: Rule irule03a : WITH leading \x00
Nov 9 04:46:01 local/tmm info tmm[5158]: Rule irule03a : Text: ÀHello World
Nov 9 04:46:01 local/tmm info tmm[5158]: Rule irule03a : Text hex: 0001020348656c6c6f20576f726c64
Nov 9 04:46:01 local/tmm info tmm[5158]: Rule irule03a : Text encoded: 7749414241674e495a5778736279425862334a735a413d3d
Nov 9 04:46:01 local/tmm info tmm[5158]: Rule irule03a : Text decoded: c08001020348656c6c6f20576f726c64
Nov 9 04:46:13 local/tmm info tmm[5158]: Rule irule03a : WITHOUT leading \x00
Nov 9 04:46:13 local/tmm info tmm[5158]: Rule irule03a : Text: Hello World
Nov 9 04:46:13 local/tmm info tmm[5158]: Rule irule03a : Text hex: 01020348656c6c6f20576f726c64
Nov 9 04:46:13 local/tmm info tmm[5158]: Rule irule03a : Text encoded: 415149445347567362473867563239796247513d
Nov 9 04:46:13 local/tmm info tmm[5158]: Rule irule03a : Text decoded: 01020348656c6c6f20576f726c64
Regards
Kurt Knochner
