Zen_Y's avatar
Zen_Y
Icon for Cirrus rankCirrus
Dec 08, 2024
cpu consumption on HA standby devices is higher
hi everyone,
in some cases of devices that have HA configuration, the cpu consumption on the standby device has a higher percentage compared to the active device.
checking the top menu, the highest rating on both devices is java. and I think that's normal. has anyone ever experienced something similar, the cause of the standby device cpu being higher than the primary device?
thank you
  • Hello Zen_Y,
    Which is your OS version and how much CPU your are observing in the standby device. other than Java, which process showing higher. please provide a snap
    BR
    Aswin
