zeropixel_23561's avatar
zeropixel_23561
Dec 23, 2015
copy and paste issue in F5 LTM VM console with VMWare
I have issue to copy text from my local F5 LTM VM console with VMWare. I am able to do that with other VM in VMWare. I also checked the copy and paste setting is enabled. Any ideas why?
  • I don't believe console access will allow copy and paste. I would suggest you use SSH if you wish to copy and paste stuff in and out of the command line.
  • I tried to ssh but not successful with the following error. I need to enable some setting?
    RSA host key for 10.128.1.245 has changed and you have requested strict checking. Host key verification failed.
  • What ssh program are you using? You will either need to manually trust the ssh key from the BIG-IP in that program or turn off strict key checking to accept the key presented by the BIG-IP, then you should be able to turn it back on if you so desire.
