pr's avatar
pr
May 18, 2017
Cookie based persistence issue
Hi All,
I am facing one problem with one of my client billing application . I am using SNI feature with host based redirection of websites based on Irule ( like abc.gef.com then go to x pool if def.jec.com then go to y pool like that ) and I have also configured the default pool with cookie based primary persistence & source IP based persistence enabled. Now what my client is saying that whenever users login with their credentials website is serving the content with cookies are enabled to browser. Now problem arises when user logout the app without closing the browser since session is disconnected by looging out idealy cookie should also be removed by they are saying that cookie still remains . So again user login to the website it will be directed to same server. Do I also need to enable the One connect Profile to solve this thing ?
  • JG's avatar
    JG
    Trying removing the source IP based persistence profile.
  • P_K's avatar
    P_K
    Can you explain this?
