cookie base persistence
Hi All,
I have 2 virtual servers http_vs and https_vs on the same domain pointing to the same pool
our default web site is http but when it comes to login and purchase, users are redirected to https.
I want to achive cookie base session persitence with an idle timeout of 10 min.
Our application uses JSESSIONID as the cookie.
I tried with the available irule for jsessionid from here https://devcentral.f5.com/wiki/iRules.Weblogic_JSessionID_Persistence.ashx. but this do not maintain session when switched from http to https.
I used even this irule https://devcentral.f5.com/wiki/iRules.HttpToHTTPsCookiePersistence.ashx but issue is with application timeout.
So I modified the irule as below.
This logs information about the TCP connections on *both* sides of the full proxy
set client_remote "[IP::client_addr]:[TCP::client_port]"
set client_local "[IP::local_addr clientside]:[TCP::local_port clientside]"
Log details for the request
log local0. "| REQ | $client_remote | $client_local | server_local | server_remote | [HTTP::cookie value ISASESSIONID] | [HTTP::uri]"
if { [HTTP::cookie exists "ISASESSIONID"] } {
persist uie [HTTP::cookie value "ISASESSIONID"]
when HTTP_RESPONSE {
set server_remote "[IP::server_addr]:[TCP::server_port]"
set server_local "[IP::local_addr serverside]:[TCP::local_port serverside]"
if { ![HTTP::cookie exists "ISASESSIONID"] } {
if { [HTTP::cookie "JSESSIONID"] ne "" } {
set newCookie [HTTP::cookie value JSESSIONID]
HTTP::cookie insert name "ISASESSIONID" value $newCookie path /
persist add uie [HTTP::cookie value "ISASESSIONID"]
log local0. "| RES | $client_remote | $client_local | $server_local | $server_remote | [HTTP::cookie value ISASESSIONID]"
Can someone verify if this is the best way to achive cookie base persistence with application timeout?
- hoolio
If it's the same pool for both virtual servers on the same domain, you can use a default cookie insert persistence profile without an iRule.
Aaron - Mario_Almeida_5
Hi Aaron,
Default insert cookie has no option to specify timeoutltm persistence cookie cookie {
cookie-name none
expiration 0
hash-length 0
hash-offset 0
method insert
mirror disabled
Mario
- hoolio
Hi Mario,
By default LTM sets a session cookie which the client should keep in memory until the browser is closed. If you want a time expired cookie you can set the expiration.
That said, why do you want the cookie to expire? As long as the cookie is there longer than the application's session timeout there is no harm in it being there longer. The persistence cookie has nothing to do with accessing the application after the application session expires--it just triggers TMM to send the client's requests to the same pool member.
Aaron
