MM_F_147944
Apr 06, 2014Convincing document on differencing between Big IP 3400 and 4000s
I want a convincing document to convince my customer to migrate from 3400 to 4000s
- giltjr
Why do you want them to migrate? Reasons to migrate to a new hardware platform are basically:
A) Current platform is no longer supported or will be going out of support within the next 12 months.
B) Current platform does not support a newer level of firmware/software the has a function, or functions, that your environment requires.
C) Your current platform does not provide the necessary performance or resources.
Upgrading just to upgrade does not accomplish anything.
