sstafford
Mar 27, 2009Connections to outside databases timeout
Hi All,
I have a situation where outgoing connections from a pair of load-balanced shibboleth servers to a non-load-balanced oracle database are timing out after five minutes. Prior to being moved to the F5 LTM, this was not happening.
We addressed a similar problem with ssh sessions by adding some variables to the sshd_config on the servers in question, but I'd prefer to address on the load-balancers themselves.
Looking at the tcp profile, it would appear that I might be able to fix this by using a custom tcp profile with an increased idle timeout, or by doing something similar with a persistence profile, but neither has worked so far, according to the customer.
Has anyone else run into this or something similar? Am I even looking in the right place to address this issue?
Thanks,
Sid
- hoolio
Hi Sid,
Are the outbound connections to the DB using a VIP with SNAT automap? If so, you might be hitting a hardcoded 300 second timeout on the SNAT automap. Take a look at the following solutions for some additional info and options:
SOL7606: Overview of BIG-IP LTM idle session timeouts
https://support.f5.com/kb/en-us/solutions/public/7000/600/sol7606.html (Click here)
SOL6017: The BIG-IP LTM SNAT automap has a static timeout value of 300 seconds
https://support.f5.com/kb/en-us/solutions/public/6000/000/sol6017.html (Click here)
Aaron - sstafford
Thanks Hoolio, those kicked loose enough mental debris that I was able to address the behavior. Essentially the problem originated with the idle timeout setting on a FastL4 profile associated with a Wildcard virtual server--set by default to 5 minutes. If I increase that setting to 10 minutes, then the database connection problem goes away, as the idle timeout on the F5 side is now longer than that of the database servers themselves. Here's the entry from the bigip.conf for the new FastL4 profile, should anyone be interested;
profile fastL4 fastl4HiTimeout {
defaults from fastL4
reset on timeout enable
reassemble fragments disable
idle timeout 600
tcp handshake timeout 5
tcp close timeout 5
mss override 0
pva acceleration full
tcp timestamp preserve
tcp wscale preserve
tcp generate isn disable
tcp strip sack disable
ip tos to client pass
ip tos to server pass
link qos to client pass
link qos to server pass
rtt from client disable
rtt from server disable
loose initiation disable
loose close disable
software syncookie disable
