Anesh's avatar
Anesh
May 27, 2014
Connection table entry removed after idle timer reaches tcp keep alive value
Problem: i am doing a telnet to a VIP configured on an LTM and the Connection table entry removed after idle timer reaches tcp keep alive value configured which is 60 seconds and also the i see the idle time counter resetting to zero which is expected My question is why is the connection table entry removed??
Below is LTM Config
ltm virtual testvip { destination 6.6.6.6:9041 ip-protocol tcp mask 255.255.255.255 persist source_addr { Default yes} pool testpool profiles tcp_test snat automap
ltm profile tcp tcp_test {app-service none defaults-from tcp-lan-optimized keep-alive-interval 60 }
