Matjaz_Lenarcic's avatar
Matjaz_Lenarcic
Mar 01, 2024
Connection reset
Hi everyone,
Recently i have a problem with iRule to redirect uri to url with error secure connection failed - connection reset. I use the iRule below to redirect.
if { [HTTP::uri] equals "/"}
    HTTP::redirect "https://[HTTP::host]/example/"
Can anyone help me?
regards
Matjaž
  • I don't see anything wrong with the code.
    I would use developer tools in the browser to see if the redirect is received and maybe get some more info there.
    Also a packet capture could help.
  • What does the virtual server configuration look like? Do you have an HTTP profile applied? Client SSL profile? Do you have any other iRules applied to the virtual server which may be conflicting with this iRule?
